I have this circuit below.
I have an issue where, when the input turns on the transistors, I see a spike in the nearby power supply rail. I have other power supply rails such as 3.3V and 5V. Whenever, the transistor turns ON, I see a spike of say 15V peak to peak on the 3.3V rail. This causes my ICs connected to 3.3V malfunction.
However, the spike of 15V peak to peak is not happening always. The amplitude of the peak to peak spike varies by say +/-5V
Attached in the circuit image.
Can someone let me know why this happens and what fix I can try?
