Author Topic: Source Code Analog Devices CN0359  (Read 472 times)
Offline alnstn10Topic starter
  • Country: id
« on: July 05, 2022, 02:55:03 am »
I've downloaded the source code for the analog device eval cn0359 eb1z, but I'm still confused about the location of the main program, because if you look at the folder there are lots of source code for each feature of the analog device eval cn0359 eb1z.
do I have to compile all the source code? If so, how do you compile it?
(source code in cpp format)
source code links:https://wiki.analog.com/_media/resources/eval/user-guides/circuits-from-the-lab/cn0359/cn0359-sourcecode-reva.zip
Online ledtester
Re: Source Code Analog Devices CN0359
« Reply #1 on: July 05, 2022, 02:07:07 pm »
In the Release directory there is a makefile. You'll also find a pre-compiled CN0359.bin file there.
Flashing instructions may be found here:
https://wiki.analog.com/resources/eval/user-guides/circuits-from-the-lab/cn0359#how_to_download_binary_firmware_to_the_cn0359
As for the steps to recompile the firmware, the best I could find is:
https://wiki.analog.com/resources/eval/user-guides/circuits-from-the-lab/cn0359#software_development_environment
which only lists the various toolchain components used. The files might already be organized as an Eclipse project and invoking the recompile action in Eclipse might just work.
