Don't touch any soldering system that is not fully user temperature variable.
If you have to change the tip to change temperature, avoid.
Great for production use, hopeless for general lab/electronics use
Sorry Dave but I have to violently disagree here. 'Hopeless' is just bollocks.
Ok, poor choice of words.
They are less flexible and more inconvenient.
As long as the iron has enough power and good thermal coupling to maintain a constant temp with varying loads without overshoot there is really no need for temperature adjustment.
Funny how they make all those different temperature tips then isn't it?
The Metcal STSSS/MX systems are without doubt the best iron you can buy. I have no experience of their lower-end irons.
Fixed temp, yes, one of the best irons you can buy.
I do everything from 0.5mm QFNs and TQFPs to soldering M4 screw terminals into heavy-copper boards to carry 30 amps with the same tip temperature - in about 20 years of owning Metcals in a development environment I've never felt any need to have a temperature adjustment.
That's perhaps because you are used to using a fixed temp iron.
I've used fixed temp irons too, and you get used to them, just like you do to any iron with different technology, tip types and thermal capacities etc.
But when you have a good variable temp iron you find it's just more versatile and generally don't want to go back to a fixed temp iron after using one for while.
As always, YMMV.
Can you explain exactly why you think you need temperature adjustment on a good iron? Except maybe for melting plastic.
There are plenty of reasons, which is why they make different temp fixed iron tips. Metcal have anywhere from 500F to 800F tips. Why do you think typical tip temperatures are well above the usual melting point of solder?
Which temp tip do you use, and why?
There are all sorts of theory like being able to deliver heat quicker without applying as much pressure for shorter periods, different solder and flux material types, thermal capacities of the parts etc etc.
So a variable temp iron is a more versatile and convenient tool, simple as that.
If you don't have different temp tips in your soldering kit then I'd have to say you are not properly equipped. Yes, you can "make do" with one temp, but it's not ideal for all purposes.
Dave.
