I am looking to do occasional electronics projects some SMD but mainly though-hole stuff the iron is likely to not see a great deal of use.
A lot of stations could fit the bill. It depends on how cheap you are and what you are using now. You can upgrade, incrementally, and you will have a few more Xmas's to look forward to. But if you live in the US, the Hakko 888 is too cheap to ignore. Elsewhere, it might cost a little more. But I would probably take it over an Ersa, even in Europe where Ersa Nano/Pico becomes similar in cost, esp if I only soldered occasionally. Search google or eBay for "broken" or "repair" + Hakko 888, and you will come up empty. (Ersa has a proprietary display that can die. Also have seen bad triacs and other issues.) Hakko also has some very great SMD tips that Ersa doesn't make.
The only problem is if you buy an 888, you will need a new Xmas present. You'll be done shopping for soldering irons for the next 30 years. It has the quality where it counts. The transformer, the housing, the handpiece, and the stand. It has a great tip selection with high quality, long service life, and low cost. The electronics are very basic and pretty much bombproof. It will get the job done, and it will do it comfortably and efficiently. The tips you use will still likely be in production/available by the time you're dead, and the tips are easy to source and identify.
TS-100 has good reputation on the forum, but for occasional use, at home, as a primary iron, it is a bit of a stretch. You're relying on a bitty DC jack and an iron tip/heater that connect by spring contacts. For a tool whose sole purpose is to make electrical connections, you are relying on a bunch of electromechanical connections and LCD that can fail for a variety of reasons, let alone the switchmode supply which has caps that will eventually dry out. And the only way you can repair this thing and/or splice a connector on a new psu is with another soldering iron. Not to mention where's the stand?
