With a steady hand you can easily patch Dupont breakout leads to these. A blob of solder on the half crown, a tinned lead end cut off to about 1.6mm and then connect one to the other with the iron. Not a production solution, but wrapped in self-amalgamating tape it's surprisingly durable. On a plane right now but will post example pics later.
Dave
