Author Topic: Soldered 0805 vs 0603 vs 0402 vs 0201 vs 01005 vs 008004 today :)  (Read 30738 times)
Offline alexgTopic starter
Hi All, just wanted to share cool experiment I did today, I soldered few capacitors today on same board starting from 0805 down to 008004, all the way down to 0201 is super easy, at 01005 that's where fun begins but still quite possible even with 10x magnification. I may do this over again in couple weeks because pads for 008004 came a bit too small so part offsets when solder start flowing, which is fine but not aesthetically what I wanted :)
I used to think 0603 is small :)
The following users thanked this post: thm_w, ^_^, tablatronix, TheDane, fonograph, analogo
Offline Rerouter
Re: Soldered 0805 vs 0603 vs 0402 vs 0201 vs 01005 vs 008004 today :)
« Reply #1 on: February 11, 2017, 09:10:08 pm »
This will make a great reference picture aswell for many future readers, its sometimes hard to grasp just how small they are,
I've had to do 01005 by eye before, It wasn't hard, but it wasn't easy, 008004 by eye is something i hope i never have to do.
Offline Fred27
    • Fred's blog
« Reply #2 on: February 11, 2017, 11:23:04 pm »
008004? WTF? You just made that up.
The following users thanked this post: rx8pilot, IRFP460
« Reply #3 on: February 11, 2017, 11:41:24 pm »
Its ridiculously small, this image from net shows them lined up on the match head and smallest one there is 01005, so 008004 is twice smaller that that :) if you put it on your finer tip it will sink between fingerprint lines :)
http://www.surfacemountprocess.com/uploads/5/4/1/9/54196839/8280339.jpg?302
The following users thanked this post: fonograph
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: February 12, 2017, 12:31:51 am »
0201= 0603 metric. 01005=0402 metric...what could possibly go wrong....?
Guess why I have a strip of 01005 resistors in an unopened Digikey bag my drawer... ( it does occasionally come in handy when someone comments that 0402's are tiny.)
Incidentally....
2512, 2010, 1206, 0603, 0402, 0201, 01005...  all 2:1 aspect ratio
so why 0805 and not 0804? Anyone know?
Day Job: Mostly LEDs
Offline hwj-d
  • save the children - chase the cabal
« Reply #5 on: February 12, 2017, 12:44:41 am »
Im so shaky, i only work with 1609 or 1610...  :-DD
Offline rx8pilot
« Reply #6 on: February 12, 2017, 12:47:01 am »
Incidentally....
I suspect it is arbitrary. Fun Question though.....
Offline Pedro147
  • I have plenty to learn
« Reply #7 on: September 30, 2017, 08:02:04 am »
  Thanks for the image alexg. I just started doing some SMD work with 0402 (imperial 1.0 x 0.5mm) and the thought of using these smaller sizes is horrific  |O
Offline Brumby
« Reply #8 on: September 30, 2017, 12:33:13 pm »
I've hand soldered down to 0603 without too much difficulty. 0402 was fun, though - but I think that was more from the fact I was doing it on matrix board and the pads were a little too widely spaced.
I have some 0201 resistors I bought cheap off eBay for challenging myself.  Haven't opened them yet.
Offline amyk
« Reply #9 on: September 30, 2017, 03:47:23 pm »
You've beat this guy who hand-soldered 01005 a few years ago: http://donkey.vernier.se/~ghlargh/01005/index.html :-+
Offline Neganur
« Reply #10 on: September 30, 2017, 06:50:50 pm »
I used to think 0201 was quite doable but that was before my eyes got bad :P almost everything has to happen under the microscope nowadays.
Anything smaller than that risks getting damaged by tweezers too easily imo! Rather just reflow that stuff.
Offline timgiles
  • Programmer, DB architect
« Reply #11 on: September 30, 2017, 08:22:08 pm »
Amazing. Not sure I could do that (hand solder) below 0402 - not even sure I could place those two smaller components and reflow it!
Gonna have to buy some of them to show my colleagues - they thought 0201 was crazy.
Offline KL27x
« Reply #12 on: September 30, 2017, 09:43:52 pm »
I wonder what the vacuum pickup needles look like for those things. The tweezers look gigantic.
Offline Brumby
« Reply #13 on: October 01, 2017, 02:42:10 am »
At that size, almost anything can cause component movement problems.
Six molecules of condensed rosin vapour on the tip of the tweezers is enough to act like a blob of Blu-tack.  (Perhaps a slight over-exaggeration.)
Offline Pedro147
« Reply #14 on: October 01, 2017, 05:15:54 am »
That's no exaggeration at all  |O
 SMD components sticking to the tweezers is the bane of my life.
The following users thanked this post: Muxr, tooki
Offline ebastler
« Reply #15 on: October 01, 2017, 07:24:44 am »
Just curious: What size of tip, and what diameter of solder did you use? Did you add extra flux?
Offline Psi
« Reply #16 on: October 01, 2017, 11:11:42 am »
When 1206/0805 surface mount PCBs first started to appear the old 'gray beards' complained that 'electronics just wasn't serviceable any more'
Now we have 008004 and people are still trying to solder it at home :D
Offline nanofrog
« Reply #17 on: October 01, 2017, 12:40:14 pm »
Cleaning frequently with acetone will improve matters IME (stuff from a paint store/dept., not nail polish remover).  ;)
Offline NivagSwerdna
« Reply #18 on: October 01, 2017, 01:27:34 pm »
As a hobbyist I think 0603 is the sweet spot... that size is where components get super cheap so you can order 100s rather than 10s.
Offline plazma
    • Homepage
« Reply #19 on: October 01, 2017, 01:53:54 pm »
And it is the smallest size with size code on resistors.
Offline Pedro147
« Reply #20 on: October 04, 2017, 12:00:56 pm »
Thanks :) Yes I tend to use Isopropyl but it's just a PITA having to do it all the time.
Offline TheDane
« Reply #21 on: October 05, 2017, 08:00:59 am »
A quick question - your tweezers are non-magnetic, right?
(if it isn't - get a set which is  ^-^)
Edit - changed 1=1 to 1=0; (if it isn't - get a set which isn't  ^-^)
« Last Edit: October 05, 2017, 08:04:24 am by TheDane »
Offline analogo
  • Country: at
« Reply #22 on: October 05, 2017, 08:11:34 am »
Metric 0603 is small!  8)
Offline Mr. Scram
  • Display aficionado
« Reply #23 on: October 05, 2017, 08:26:25 am »
Hol' up. There are two 0603s, depending on which side of the pond you are?
Offline Rerouter
« Reply #24 on: October 05, 2017, 09:43:46 am »
even on the metric side of the pond, i would imagine 0603 would mainly be thought of as the imperial footprint.
