Interesting. I thought that slide-on tip systems had no future, but we see that new models are released. Are they not much worse in terms of performance than cartridge tip systems? I would assume that Hakko knows what to do, so probably they are good? How do they compare to, say, T12?
Ersa released its latest slip-on tip system, the 142 series, a year and a half ago (snuck in on the i-Con Trace production station) with the broader release last July with the i-Con Mark II stations. The original i-Con series was introduced in 2007, and I had that at my old job, and at home. The update claims 20% improved performance.
I’ve never used T12, but I have used JBC T245 and Pace TD-100, and while the Ersa doesn’t heat quite as fast, it’s still under 10 seconds from cold to ~350C. It has no trouble with anything I throw at it. In actual use, there’s no noticeable difference between JBC and Ersa. (But I prefer the Ersa handpiece.)
Let’s put it this way: I got to buy a new soldering station at work last month. Anything I wanted, more or less. I chose the Ersa i-Con 2G Mk II. JBC stations cost roughly the same, but the tip costs are incomparable, costing around 3x as much for basic tips, 2-3x as much for more exotic shapes. That, and easier tip availability, more than made up the tiny advantage in heating speed of the JBC.
Cartridge heater systems can be great, but slip-on tip systems can be great too. A really well-done one like Ersa is functionally indistinguishable in everyday use. IMHO the quality of the control loop can make an even bigger difference (as evidenced by Pace’s somewhat anemic performance in the ADS200 due to a very conservative PID tuning.)
