Author Topic: Manufacturer logo  (Read 995 times)
Offline ApofviewTopic starter
  • Country: mon
  • Only change is constant.
Manufacturer logo
« on: November 11, 2021, 05:01:23 pm »
Identified short in two back to back diodes.
Searched online but I was unable to find this manufacturer.
I think they are zener diodes, found some similar schemes online.
  • Country: mon
Re: Manufacturer logo
« Reply #1 on: November 11, 2021, 05:24:04 pm »
Found logo on (https://www.s-manuals.com/smd):
Taiwan semiconductor
NTJ code is Surface Mount Transient Voltage Suppressor 190V
Searching for thru-hole equivalent
Offline Benta
« Reply #2 on: November 11, 2021, 06:28:27 pm »
190 V is rare.
Closest would be P6KE180CA or P6KE200CA.
  • Country: mon
« Reply #3 on: November 11, 2021, 08:00:15 pm »
Tjank You Benta,
Tomorrow will go to lokal shop to check availability.
I'm tempted to test device without TVS diodes...
  • Country: mon
« Reply #4 on: November 12, 2021, 02:49:05 am »
NTJ ia actually min 190V max 210V and code is P6SMB200A
So equivalent is probably P6KE200CA
  • Country: mon
« Reply #5 on: November 12, 2021, 08:11:31 am »
Local shop has only P6KE250, protected cap is 250V rated...
Can I use 200V zenner instead TVS diode?
  • Country: mon
« Reply #6 on: November 12, 2021, 05:35:21 pm »
Installed P6KE250CA, tested, device works 😁
Ordered original part P6SMB200A, hope it will arrive in time ...
TVS and zenner have different purpose, and are not interchangeable.
