Author Topic: Soft start a 12V DC motor, max 250A, possible?  (Read 580 times)
Online BiddaTopic starter
  • Country: no
« on: July 05, 2024, 03:03:54 pm »
Hi
I have a boat (20ft) with an bow thruster that is to big, I want to soft start motor, aprox 2-3 sec.
It is an 12V DC motor and in tecnical data it says max 245A.
Is i possible to find this soft starter in stock, enyhvere??
BR
Brede
« Last Edit: July 06, 2024, 05:09:37 pm by Bidda »
Offline Benta
Re: Soft start a 12V DC motor, max 250Ah, possible?
« Reply #1 on: July 05, 2024, 04:59:45 pm »
Ah? Do you mean A? There's a hell of a difference.
Offline BILLPOD
« Reply #2 on: July 05, 2024, 05:23:51 pm »
Even if it is A,(Amps), 245 is a lot. :horse:
Offline themadhippy
« Reply #3 on: July 05, 2024, 05:38:56 pm »
245 is a lot.
Is it? T'is not even 3KW
Offline BrokenYugo
« Reply #4 on: July 05, 2024, 05:45:19 pm »
What type of motor is this? Does it not already have a speed controller? I would think that would be where any soft start/limited ramp up rate would be implemented in such a system.
Offline johansen
« Reply #5 on: July 05, 2024, 06:17:07 pm »
Find a 500 amp carbon pile battery load tester, with a knife switch to bypass it.
Offline BeBuLamar
« Reply #6 on: July 05, 2024, 06:23:38 pm »
They make speed controller for bow thruster. A speed controller would be a soft start.
The following users thanked this post: Bidda
  • Country: no
« Reply #7 on: July 06, 2024, 12:40:57 pm »
Yes, A, my bad
  • Country: no
« Reply #8 on: July 06, 2024, 12:42:03 pm »
No speed controll, only on/off
  • Country: no
« Reply #9 on: July 06, 2024, 12:47:47 pm »
Yes, Sleipner have a set I can buy, it is expensice (2500 EUR). A softstarter should be less costs and work.
  • Country: no
« Reply #10 on: July 06, 2024, 05:35:12 pm »
Thx, can you make me a drawing of how you think? Link to equipment?
Offline mikerj
Re: Soft start a 12V DC motor, max 250A, possible?
« Reply #11 on: July 06, 2024, 07:41:42 pm »
If it's a regular brushed motor you should be able to find something much less expensive e.g. https://www.4qd.co.uk/product/pro-160/
  • Country: no
« Reply #12 on: July 06, 2024, 07:57:03 pm »
THX, Yes it is a brushed motor, I will contact them to ask for a solution :-)
Offline johansen
« Reply #13 on: July 06, 2024, 10:41:40 pm »
carbon pile load testers are a stack of about 25, 1/8" thick carbon disks 3" diameter. flat plates on both ends connect to the battery terminals.
the adjustable knob tensions a spring which compresses the stack together. works from about 0-500 amps somewhat non linearly with time because as far as i remember, the carbon shrinks when it heats up.
you could make your own using two flat plates, spring tension etc.. but instead of carbon disks you could strip the copper off of arc gouging rods and cut them and lay them like cordwood in an alternating cross pattern.
or just buy 50$ worth of NTC resistors.
« Last Edit: July 06, 2024, 10:43:33 pm by johansen »
Offline WokeJordon
  • Country: cn
    • DONGMING MOTOR
« Reply #14 on: Yesterday at 07:42:09 am »
Do you means Max 250mA?
woke Jordon
DONGMING MOTOR
Offline Tim S
« Reply #15 on: Yesterday at 08:46:23 am »
If it's too powerful, then elctronic PWM is one way to go, but you could always change the propellor for a smaller diameter or a finer pitch one. PWM and marine are not good bedfellows!
Essentially the thruster  motor is a DC starter motor and will easily pull hundreds of amps. In a yacht there is often a load battery next to the motor, long cable runs cause voltage drop when trying to pull 200A. If you have a battery next to the motor, try disconnecting the battery - the long cable run from the engine battery will act as a ballast resistor. Beware - the cables will get hot! If this is too much, then a delayed switching in of the load battery could work. When you press the 'thrust' switch, the motor can start on the long cable then a relay/solenoid can switch in the load battery after - say 2 seconds to save overheating the cables.
Tim.
  • Country: no
« Reply #16 on: Today at 09:20:07 am »
No, 250A is max
