Author Topic: Help with circuit build  (Read 437 times)
Offline Kban1337Topic starter
« on: June 27, 2024, 07:13:10 pm »
Hello,
I am in the process of building this circuit and need info help with a few things.
The 4of275v capacitors, is it 4 capacitors or one? And how would I connect them to the wire?
Where it says 1/4" gap, do I actually leave a gap between the wires?
What wires would you recommend for the antenna and what comes out of the ignition coil?
Thank you
Offline xvr
  • Country: ie
    • LinkedIn
Re: Help with circuit build
« Reply #1 on: June 27, 2024, 08:16:54 pm »
From your questions and schematic I could conclude that you will kill yourself trying to make this 'circuit'. Are you shure that you ready to put your life on the line for electro fence?
I personaly don't want help you to commit suicide  :(
The following users thanked this post: DimitriP
Offline JustMeHere
« Reply #2 on: June 27, 2024, 08:31:18 pm »
Agree with other poster.  Since you don't know what a spark gap does and why it's there, spend the $40 and save your life.
Offline zapta
« Reply #3 on: July 12, 2024, 12:17:16 am »
+1
Pick a low voltage project.
Offline jonpaul
« Reply #4 on: July 12, 2024, 06:49:52 am »
Jean-Paul  the Internet Dinosaur
