Author Topic: SMD shaft pot - Possible?  (Read 3947 times)
Offline made2hackTopic starter
    • Made2Hack
« on: July 01, 2015, 06:39:26 pm »
Hello,
So I'm essentially looking for a shaft potentiometer but that is surface mount. I don't really want to mount a large TH pot by just soldering the tabs to the board.
Ideally, I would like the low profile of an SMD trimmer but with a shaft. Do they exist? Looking on the suppliers website, doesn't really seem to.
This is what I would ideally want:
I found the trimmer knobs but I want to know if they are compatible so that once stuck to the trimmer, they would make essentially a shaft. I'm not looking for a trimmer tool. The example above probably would not work but you get the idea what I want to achieve.
Here's a list of TME's trimmer knobs.
Online Ian.M
Re: SMD shaft pot - Possible?
« Reply #1 on: July 01, 2015, 07:46:05 pm »
JFGI - image search for: SMD potentiometer
Offline Mr.B
« Reply #2 on: July 01, 2015, 07:55:53 pm »
I have used Bourns before.
Datasheet of what I used below.
Mouser currently carrying 10K and 50K linear.
Offline Richard Crowley
  • KJ7YLK
« Reply #4 on: July 01, 2015, 09:14:57 pm »
Yes there are several products from several vendors.
Google image search turns up many candidates if you search for: smd potentiometer
