Author Topic: (Sloved)Way to use PCI card without desktop PC?  (Read 5065 times)
Offline sam1275Topic starter
« on: March 26, 2015, 01:43:35 pm »
Hello.
I may have asked this in another thread, but not a dedicated one.
I want to use a PCI card without desktop computer, but laptop/tablet, because I want my system to be portable, but all I can find are too expensive, such as:
http://www.magma.com/1-slot-pci-expansion
The PCI card is too special to be replaced by another card with different interface, so can I have any cheaper options?
Thank you.
« Last Edit: March 26, 2015, 04:57:37 pm by sam1275 »
Offline Alex Eisenhut
  • Place text here.
Re: Way to use PCI card without desktop PC?
« Reply #1 on: March 26, 2015, 01:48:13 pm »
Yeah wow, that's expensive. But what's so special about this PCI card?
Offline iamdarkyoshi
« Reply #2 on: March 26, 2015, 01:51:46 pm »
I know gaming laptops use a tiny pci express card for graphics, but I really dont know. Seems like building a pc inside of an armored briefcase would be easier.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #3 on: March 26, 2015, 01:55:14 pm »
do you have a link to the PCI card you're using?
There may be other ways... the magma box is ridiculously expensive.
FWIW it should be selling for under $250-300
Don't ask a question if you aren't willing to listen to the answer.
« Reply #4 on: March 26, 2015, 02:17:59 pm »
A camera controller: http://www.ebay.com/itm/Roper-Scientific-Photometrics-PCI-Board-Card-01-447-251379-D0134225D5-/361195146645?
It's already very hard to find, and very rare.
« Reply #5 on: March 26, 2015, 02:19:00 pm »
Yes, my last plan is to build an ITX PC myself.
« Reply #6 on: March 26, 2015, 02:24:00 pm »
Yes, I already post the ebay link, and this is my previous posts asking for help:
https://www.eevblog.com/forum/projects/usb-to-pci-adapter/
https://www.eevblog.com/forum/projects/help-identifying-connector-type-pci-card-model/
I finally find the card, but it's too big to carry a full computer with me all day.
Offline SL4P
« Reply #7 on: March 26, 2015, 02:27:33 pm »
yep it looks like a hard to support part.
although it seems cheap enough when 2nd hand...
so I guess you have no support for other PCI capture cards like osprey etc....
if we can get past the  card specific 'special' features, there may be other options available...
ok... looking at the other post thread, you're painted into a corner...
the camera interface is very specific (not the bnc video I was expecting) !!
You also want to make sure any PCI adapter can handle the data rates the interface is expecting.
« Last Edit: March 26, 2015, 02:34:21 pm by SL4P »
Offline Monkeh
« Reply #8 on: March 26, 2015, 02:32:08 pm »
How about going to PCI-E and then a bridge to PCI?
http://www.hwtools.net/Adapter/PE4H%20V3.2.html
« Reply #9 on: March 26, 2015, 03:17:44 pm »
Thank you!
« Reply #10 on: March 26, 2015, 03:19:41 pm »
I've seen this before and didn't want the 2 stage method, but now see it again and I think this will be the best way, really thanks!
Offline Balaur
« Reply #11 on: March 26, 2015, 03:34:11 pm »
Just go for a mini ITX case and motherboard. Standard, affordable and very portable.
You may not want to carry a screen with you. In this case, you can use VNC and a laptop for control.
Offline PeterFW
    • Stuff that goes boom
« Reply #12 on: March 26, 2015, 04:09:57 pm »
A tablet would be much smaller ;)
Battery, micro atx board, 90ยบ pci riser and a dcdc converter would be fairly small if you control it using a tablet and a custom interface or vnc.
