That is fine, within 5% of the voltage which is fine. What is the voltage across the C4, C5 and C6 when it is delivering this low voltage. That will tell if it is in the rectifier and RC filtering or in the regulator. There should be around 300-350V across C7, and over 260V across C4, basically a drop of around 20V across each resistor.
