I am not sure I agree that two 1 kV capacitors in series will withstand 2 kV. Unless you add equalizing resistors.
Silver mica is just a contruction method. The capacitors should work, as long as they don't break down. In addition, the RF current specification needs to be respected. This varies widely with different capacitors, so check that first.
