Author Topic: Triac help  (Read 2080 times)
Offline FlumpTopic starter
Triac help
« on: April 24, 2014, 07:11:24 am »
I am using a BTA 41 Triac in a crowbar circuit which is triggered by a zener diode
the weird thing is the crowbar triggers at slightly different voltages 16.5 and 13.something
depending on which way wound i have the + and -  on the Triac
anyone got any ideas why this should be, I thought it was just two diodes inside so shouldn't
matter which way the + and - go as it just goes closed circuit when tripped.
http://www.farnell.com/datasheets/1689729.pdf
« Last Edit: April 24, 2014, 07:54:48 am by Flump »
Offline miceuz
  • Country: lt
    • chirp - a soil moisture meter / plant watering alarm
Re: Triac help
« Reply #1 on: April 24, 2014, 07:32:40 am »
Posting your schematics would really help the people to answer your question.
Offline David_AVD
Re: Triac help
« Reply #2 on: April 24, 2014, 08:08:00 am »
The MT1 and MT2 terminals on the TRIAC are not always interchangeable from a trigger point of view.  Check the data sheet for the TRIAC you're using and read the section about the different quadrants.
Offline Richard Head
Re: Triac help
« Reply #3 on: April 24, 2014, 09:59:25 am »
That simple circuit is known to be dubious at best. The problem is that the zener leakage current and variable triac trigger current all contribute to alter the trigger point.
A much better option is to use a comparator. This eliminates both issues.
Also, thyristors have a higher surge current rating than triacs, so would be a better choice.
Dick
