Hey guys,
I'm in the process of designing a new power supply for an old Japanese computer. I have a pin out of the voltages for all pins and I can successfully turn the computer on by wiring a pico PSU to a breadboard with the 44pin high density backplane connector that connects to the computer. I press the power switch on my pico breakout board and it shorts the PS_ON line to ground on the pico turning the computer on. However when I do this I cannot press the front power button on the computer to turn it off or on.
I'm in a dilemma. Currently the design can turn the computer on but I require a second switch in the rear specifically making the front power button obsolete. There is also a software shutdown feature in the computer software that also shuts the PSU off and I'm not sure how to implement this in a circuit.
The pin that performs a software shutdown is an active high and goes low when the PSU cuts off basically when you select computer shutdown in the operating system. This I do know. I'm welcome to any suggestions to try out by others more experienced here
