Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
i want to know what a coil with 3 connections is.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: i want to know what a coil with 3 connections is. (Read 972 times)
Eamonn58
Newbie
Country:
on:
December 20, 2021, 10:27:34 pm »
I am trying to reverse engineer an alarm pizo circuit. Its the loudest I have found with a 9 volt battery.
The circuit has a CD 4069UBE inverter chip with some resistors capacitors transistors.
There is also a coil with 3 connections but I cant find a coil with 3 connectors and don't know what its called. It did have a plastic cover over it (similar to an electrolytic capacitor) which had
something like 865K written on it. I removed it and cant remember the actual number.
I am quite a novice at electronics but realise how useful it is for making cool products.
Logged
langwadt
Super Contributor
Country:
Re: i want to know what a coil with 3 connections is.
Reply #1 on:
December 20, 2021, 10:32:29 pm »
tapped inductor?
similar to end of this page,
https://itectec.com/electrical/electronic-how-does-the-component-alarm-boost-three-pin-inductor-make-a-piezo-buzzer-louder/
Logged
james_s
Super Contributor
Country:
Reply #2 on:
December 20, 2021, 10:33:16 pm »
It sounds like a tapped inductor. It's also possible that it has 3 pins but only two are actual connections with the third as a mechanical support.
Logged
Eamonn58
Gyro
Super Contributor
Country:
Reply #3 on:
December 20, 2021, 10:36:55 pm »
It could well be acting as a step-up autotransformer to increase the voltage drive to the piezo. I can't think of any other reasons for having an inductor in a battery operated smoke alarm.
Edit: Oops, as langwadt's link.
Logged
Best Regards, Chris
Eamonn58
Newbie
Country:
Reply #4 on:
December 21, 2021, 03:50:26 pm »
Thanks.
Im not sure it makes a difference but it wasnytfrom a smoke alarm but a personal alarm. I want to incorporate it into a car alarm I am making.
Logged
Gyro
Super Contributor
Country:
Reply #5 on:
December 21, 2021, 03:57:19 pm »
Ah, I must have imagined that bit (probably thinking loud alarms!). No, no difference, it should make it easier to reverse engineer.
Logged
Best Regards, Chris
Eamonn58
Eamonn58
Newbie
Country:
Reply #6 on:
December 21, 2021, 04:00:41 pm »
Thanks. That looks exactly what it is and it suggests where to get them.
Cheers.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
