What specifically make it a junk?
It's too light. That means the core (that wires are wound on) is too small. It will saturate and overheat. Wires are also too thin for the rating. When I lived in Japan, I had a 250VA version. It was larger and heavier than this thing.
My prediction is, it will get way too warm, possible smoke, possible broken wire, but I don't expect anything spectacular. I think I have a 500 watt light bulb somewhere, so I'll use that as a load. Thermo-couples on bottom, face plate, sides. Clamp on meter for current at input, Voltage at the output. Run it for one hour at half way point, and another one hour at whatever the bulb is rated. (120V?) Then rotate the slider from 0 to 120V back and forth few times. This is when I expect something to go wrong.
Breaking it isn't the point, and stressing until it melts isn't a point either. My goal is to determine, if _I_ feel safe using this at the rating. Obviously, at half way point, it won't be expending 500VA. I am a licensed electrician but this is only a partial and personal test in home setting. I don't endorse, approve, or guarantee anything and if anyone decides to buy it, they do so at their free will.
It might take me few days but I've been wanting to do this for a while, so I will do it. Just don't stay up all night waiting for it.
