Well,i just tested the led that came with the kit,its way brighter and has a vf of 1.97v,could that be the issue?,everything else looks good.
thats my pont,sounds iffy to load it untill the v out sags,that will be a lot of amps without the led,what if i stop at say 10 amps?
Well just an update,i changed the led for a decent one,adjussting vr1 gives me 12amp before current limiting,i will leave it at that,seems better than the stock 5a,goes up to 36v too,i class it as a good result,thanks for everyones help.
one thing i notice is when the led illuminates i can stil increase the output current using the volts pot!,is that normal?
I assume thats the tl-431?
When two of the 2sd 1047 trannys going sc killed the tl430 as well?
