Author Topic: Sg3525 PWM Output  (Read 132 times)
Offline mustafayilmazTopic starter
  • Country: tr
Sg3525 PWM Output
« on: Today at 11:35:39 am »
I will use this integrated circuit to operate a motor with a 5-6 ampere maksimum current. The motor belongs to a spraying machine used in agriculture.
As far as I know, each output (Qa and Qb) can reach up to 50% duty cycle. For this reason, I am thinking of combining the outputs via a diode. Is there another method? I also want to understand whether a mosfet driver is needed. The pwm circuit will operate around 300-400Hz.
Another question is that a tiny switch potentiometer will be used to turn this circuit on and off. Since the power of the switch will not be able to handle large currents, I am thinking of turning the integrated circuit on and off directly. The gate leg of the mosfet will therefore be connected to chassis with a resistor. The existing circuit was a 555 circuit and was working with a tiny pot. Will this cause a problem?
« Last Edit: Today at 11:38:27 am by mustafayilmaz »
Offline Andy Chee
Re: Sg3525 PWM Output
« Reply #1 on: Today at 01:08:14 pm »
If you want 0-100% PWM duty cycle, you have selected the incorrect chip.
A better chip would be IR2153.
Online David Hess
  • DavidH
« Reply #2 on: Today at 08:05:00 pm »
Combining the outputs with two diodes or transistors will work, but then a driver might be required.  The SG3524 has uncommitted outputs which can be combined directly in parallel.
There is nothing wrong with combining the outputs to achieve >50% duty cycle, and it is even recommended in the application notes for this type of controller, although the SG3524 would be preferred.
