It shouldn't matter. The gain of a transistor is generally not controlled very tightly, and designers shouldn't rely on a particular specific value of gain.
According to the data sheet,
http://www.st.com/web/en/resource/technical/document/datasheet/CD00000895.pdf , in table 4, it says that, at collector current of 4 amps, and Vce of 4V, the gain is somewhere between 20 and 70. Your transistors all test within this range. At a collector current of 10A, the gain is specified to be at least 5, with no maximum specified.
This design isn't very sensitive to variations in gain. If one of the transistors has a lot more gain than its neighbor, its base-emitter current will be less, but who cares?
