So what should I order from either amazon or an electronic shop that will give me what I need. I know I need at least 2 bread boards( I'll buy a pack of 10)
I was meaning one of the solderless breadboards that you can experiment with. You'll need one of those. If you intend to get into electronics, invest in one like this with three or four lengths, rather than just a single strip (I have about 10 of this size... LOL):
![](https://cdn-reichelt.de/bilder/web/xxl_ws/X400/STECKBOARD_3K5V_01.png)
Yes, you will also need a couple, what I call "proto boards", but they are often called "solderable breadboards" the same basic layout as a breadboard but meant for soldering up a permanent copy of something:
![](https://i.imgur.com/j5VAABL.png)
...which is what I think you meant buying a 10 pack of.
and. A 4017, a555 and I don't know what else?
No, that won't do what you want. I think the LM3914 is the way to go.
Try to hold off the itch to order any ICs and components yet, If I have time later today I will try to whack up an example circuit that does what you want, maybe even make a little video.
Sorry to be a pain but I really don't know what I'm doing. Should I try and buy one of those cheap diy kits to get ahold of what I'm trying to do and do some more research? Do you know where I could go to learn more about those chips or others?
Just don't get ahead of yourself.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
You don't need a kit for this, you're perfectly capable of doing it yourself from scratch, plus you'll probably learn more, faster, this way than just soldering up a kit that you don't know how it works. That will make it easier to do things like fit circuitry for brighter LEDs, etc.
