I have to design a regulated power supply with following specification;
DC output voltage: 0 to 30 V adjustable.
DC current:0 to 3A adjustable.
I am a second year under graduate student, I cant understand difference between variable current function, current limiting function and fold back current limiting?
Kindly Help me in designing the circuit and Explain the above question.
You can get 5A out of your transformer if you limit the output to half voltage. You can use a switch (acting on a relay or power mosfet, scr, etc) to change between 0-12V 5A | 0-24V 3A as various bench PSU manufacturers do.
If you want to get 30V out of your transformer, then you have to use a large capacitor to keep the ripple at minimum and limit the maximum output current to 1.5-2A to reduce the power dissipated by the transformer.
Regarding the various kind of current protection/limit/regulation, you can have (even more of this in the same circuit):
-1) overcurrent protection
a comparator wich switches-off the PSU output when the output current gets above a set limit (e.g. for battery protection or electric motor PSUs).
-2) current limit
you can use a sense resistor and the Vbe threashold of a BJT to "steal" current from the base of the pass BJT when the voltage drop through the sense resistor gets above the trhreshold. The regulation is quite coarse as the current increases when the output voltage gets down. This is a problem as a pass BJT has to dissipate a lot of power in case of shortcircuit.
-3) foldback current limit
a foldback circuit uses a trick, adding a 2 resistors voltage divider to the base of the current sense BJT of the previously described circuit, in order to reduce the current as soon as the output voltage decreases.
-4) proper current regulation
that is done by using an operational amplifier (or a differential amplifier made by discrete BJTs) and allows the PSU to work within the limits of a set voltage and current, automatically switching between constant voltage and constant current mode according to the load.
For more details I suggest you to carefully read the Agilent "DC power supply handbook"
http://literature.cdn.keysight.com/litweb/pdf/5952-4020.pdf
