Author Topic: Why do I see 60Hz mains when connecting long wire to probe?  (Read 817 times)
Offline pwnellTopic starter
« on: December 13, 2020, 06:16:26 am »
Another newbie question - if I connect a single 10ft wire that goes nowhere to the positive terminal of my 10x passive probe, and the ground is left disconnected, why do I see a 60Hz semi sinusoidal wave of 5Vpp on the scope? From where does it get induced and why such a large magnitude?
Offline ataradov
    • Personal site
Re: Why do I see 60Hz mains when connecting long wire to probe?
« Reply #1 on: December 13, 2020, 06:31:24 am »
It is a capacitive coupling. Wiring in the walls and your piece of wire form a capacitor, which passes AC current.
You don't even need the wire, you can just touch the tip of the probe with your finger. Your body is full of water and salt, so it is a decent conductor. Again, good enough to couple some AC signal.
Alex
Offline radiolistener
  • Country: ua
« Reply #2 on: December 13, 2020, 11:17:36 am »
It come from mains, your wire works as antenna. Input impedance is 1 MOhm, so it is very sensitive.
Online Doctorandus_P
« Reply #3 on: December 13, 2020, 04:32:42 pm »
A simple way to test if your scope still works is to touch the probe with a finger.
It's not unusual to measure 70Vac on your fingertip, especially when you hold your other hand near anything mains voltage related.
Offline Gyro
« Reply #4 on: December 13, 2020, 06:29:00 pm »
A small correction, he's using a x10 probe, so 10MOhm - even more sensitive.
Best Regards, Chris
« Reply #5 on: December 13, 2020, 09:40:39 pm »
Yup I verified that - touching the tip of the probe and then with the other hand wrapping it around the (insulated of course!) power cord of my oscilloscope causes a nice 10Vpp 60Hz (distorted) sine wave to appear.  Very cool stuff - thanks for explaining.
