Author Topic: Unknown oscilloscope functions  (Read 7471 times)
Offline MegaWattTopic starter
« on: January 07, 2011, 12:35:17 pm »
Hello, I have recently bought my first oscilloscope from ebay. I was just wondering, does anyone have any idea what the following buttons are for?
-Single
-Delay (Norm, search, delay)
-Hold Off
I tried them out but they don't seem to do anything special :D so I'm guessing I don't know what to do with them. Any help is appreciated! Thx!
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Unknown oscilloscope functions
« Reply #1 on: January 07, 2011, 12:42:41 pm »
sounds like something to do with the triggering, do you have the scopes manual ?
« Reply #2 on: January 07, 2011, 12:45:00 pm »
Well I have the manual online, but it didn't really help me.  :(
It is here: http://www.hameg.com/manuals.0.html, search for HM605
Offline tyblu
    • blog.tyblu.ca
« Reply #3 on: January 07, 2011, 12:53:22 pm »
Hello,
Here is the manual: http://www.opweb.de/model.php?id=356
I believe the delay and hold-off features are with respect to the trigger. Delay is in time from the trigger to the trace. Hold off is important near sweep frequency, and delays the next sweep. Not sure about single, but may activate internal trigger. Actually, not sure about any of this as I don't have a Hameg, so RTFM ;)
Tyler Lucas, electronics hobbyist
Offline tyblu
    • blog.tyblu.ca
« Reply #4 on: January 07, 2011, 12:58:04 pm »
Skimming the manual I see both Delay and Hold functions explained - please quote parts you would like explained. I don't see references to "single" anywhere. Where is it?
« Reply #5 on: January 07, 2011, 01:02:56 pm »
It sais
Single: Selects single sweep operation
Hold Off: Fine adjustment of time interval between timebase sweeps
Delay: Coarse adjustment of sweep delay time.
But I don't understand what they mean with sweeps?
Offline Bored@Work
« Reply #6 on: January 07, 2011, 01:41:04 pm »
The beam moving from left to right on the CRT. One sweep: The beam moving once from left to right.
Offline DaveW
    • WattCircuit
« Reply #7 on: January 07, 2011, 02:49:44 pm »
Hold off is used to prevent retriggering-the only time I've seen it used is on AM signals. Single should only sweep once, can see a single rising edge, or the first burst of data for example without it being overwritten
Offline JohnS_AZ
    • About.me
« Reply #8 on: January 07, 2011, 03:01:49 pm »
The only time I've ever seen the Single sweep mode used was in conjunction with an oscilloscope camera. The camera opened it's shutter, triggered a single sweep, and then closed the shutter.
I'm either at my bench, here, or on PokerStars.
alm
  • Guest
« Reply #9 on: January 07, 2011, 03:08:14 pm »
Hold off is also useful for triggering on the first train of a repetitive pulse train (eg. RS-232 with a single repeating character, you set the hold-off delay so that all bits but the first are skipped).
Single is mainly useful if you have a scope camera connected on a scope without storage. On a (digital) storage scope, it allows you to register non-repeating phenomena like power-up/down behavior.
Delay allows you to insert a certain delay between triggering and start of acquisition (the part you see on the screen). This is useful for 'zooming in' on a certain part of the signal, for example, to inspect individual bits in the pulse train example. Set time base so that one bit fits on screen, and use delay to see bits after the first one. It can also be used to make more accurate time measurements, the delay knob (in combination with the faster time base) is usually more accurate than using the graticule.
The Tektronix appnote The XYZs of oscilloscopes might be a good read, especially if you have trouble with terms like 'sweep'. It explains most basic concepts.
« Reply #10 on: January 07, 2011, 03:22:15 pm »
Ah ok i think i'm starting to understand. So I can't really do anything with the sweep option :P
When i press it, i see that it draws one sweep but it then dissapears immediatly, and on a high freq thats instantaneous. But thanks for all the replies! :P
Offline DJPhil
« Reply #11 on: January 07, 2011, 11:45:35 pm »
Yes, this is exactly what single is for, not very useful nowadays. Where would you develop the film?  :-\
I suppose if it had outputs on the back you might be able to capture and store the waveform, or otherwise play with it, one sweep at a time. I'm not sure if it's within the capability of this scope however.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #12 on: January 08, 2011, 12:08:28 am »
Many digital cameras have exposure times long enough to be useable with a single-sweep mode like this if you're really keen to experiment...
Day Job: Mostly LEDs
Offline Simon
  • Global Moderator
« Reply #13 on: January 08, 2011, 08:56:06 am »
true, any SLY will have a remote jack that will fire the shutter so you can easily wire it to the scope
Offline FreeThinker
  • Truth through Thought
« Reply #14 on: January 08, 2011, 03:59:24 pm »
Only ever seen an oscilloscope camera but not used one.It fixed to the bezel of the scope and set with the shutter open permanently, but as the mounting was light tight this was ok.The scope was then set to trigger on a non repetitive event in single sweep mode.When the scope triggered the trace was captured on the film.Normally a polaroid type camera, the exposed image could the be developed and viewed, the test repeated if required. With digital scopes this has become mainly obsolete but is still the only way to capture a trace on most analogue scopes.
Machines were mice and Men were lions once upon a time, but now that it's the opposite it's twice upon a time.
MOONDOG
Offline Simon
  • Global Moderator
« Reply #15 on: January 08, 2011, 04:40:54 pm »
hm yes you could do something similar with a DSLR using the B setting
