"In this video I have investigated the effect of safety valve in electrolytic capacitors at the time of explosion."
The point I was trying to make is that it wasn't an "investigation" - you just put 30v at 2A through them. Of course some will pop instantly, some will crack and leak, if you take 100 capacitors from the same badge you won't find the same answer.
An investigation involves several capacitors of same series, various methods of testing like continuous voltage, pulsed voltage (over the rating), negative voltage, effect of temperature on the speed of leaking etc
You just took several random capacitors and put voltage on them. Yeah, that's really conclusive, way to do determinations. It's no more different than any youtube video out there with capacitors blowing up.
