Only use on the lettering, so that it is selectively removed. In many cases it will dissolve plastics, but should not affect SM devices that are wave or IR soldered, as these generally use a resin that is quite solvent resistant. Just use on the white, you might find the soldermask underneath will come off as well, so use only in small areas.
