Author Topic: RS232-+25v switch, Looking for the right search term  (Read 6146 times)
Offline kingofkyaTopic starter
« on: January 08, 2015, 05:25:34 pm »
Basicly I just want to switch an rs232 signal on to and off of a bus.
So I can find plenty of devises that will switch that works with positive voltage, but rs232 uses negative 25v to positive 25(most stuff is lower than 25 though). I have had a few though on how to get around it but i want to know if there is a part that will do what I want so.
I was looking in here but i cant seam to find anything.
http://www.mouser.com/Semiconductors/Switch-ICs/Analog-Switch-ICs/_/N-7590c/?Ns=Pricing|0
One of my though was just 2 fets with a  diode in front of em or maybe a triac of some kind.
« Last Edit: January 08, 2015, 05:38:13 pm by kingofkya »
Offline mrgregs
Re: RS232-+25v switch, Looking for the right search term
« Reply #1 on: January 08, 2015, 06:19:28 pm »
The usual way is to use something like a MAX232 for the level shifting.
Offline Electro Fan
« Reply #2 on: January 08, 2015, 06:21:17 pm »
Do you mean you want to "invert" the signal, or maybe something else?
« Reply #3 on: January 08, 2015, 07:12:22 pm »
Well if possible i don't want to convert to ttl just deal with the signal as is. So rs232 on the bus  and the ability to switch a device on and off the bus.
Offline Wilksey
« Reply #4 on: January 08, 2015, 07:14:02 pm »
If it is just one RS232, use relays, depending on flow control you can just to TX and RX with a DPDT type.
« Reply #5 on: January 08, 2015, 09:13:32 pm »
I was goan say i want to keep it small but i had no idea you could get relays like this.
http://www.mouser.com/ProductDetail/ON-Semiconductor/NLAST4599DFT2G/?qs=sGAEpiMZZMtqO%252bWUGLBzeBJ%252biJ%252bAlmpi
Offline Paul Moir
« Reply #6 on: January 08, 2015, 09:16:49 pm »
Analog switches like that one won't work.  Look at Vis (analog input voltage):  -0.5 <= VIS <= VCC +0.5
I take it you're stuck on RS-232?  RS-485 is more friendly bus wise.
« Last Edit: January 08, 2015, 09:19:26 pm by Paul Moir »
« Reply #7 on: January 08, 2015, 09:20:24 pm »
Yeah i saw that right after i posted....
« Reply #8 on: January 08, 2015, 09:24:02 pm »
I am thinking, I should try to just throw a scr/triac  across it. http://www.mouser.com/ProductDetail/Lite-On/MOC3022S-TA1/?qs=sGAEpiMZZMteimceiIVCB4wfliURD97K%2fE0dMo%252bBKxo%3d
I just wonder how that will effect the signal. I have a feeling it will round off the signal.
« Last Edit: January 08, 2015, 09:31:13 pm by kingofkya »
Offline Paul Moir
« Reply #9 on: January 08, 2015, 09:34:21 pm »
You'd need to drive the gate both ways so it would be two SCRs, one of which would need a negative voltage.  Then you'd have to figure out how to turn it off.  Possibly a FET optoisolator might work easily enough?
« Reply #10 on: January 08, 2015, 09:51:41 pm »
Yeah thats what i am thinking the opto would make it easy to drive. Just need to test it to see if it cases any data  issues. I think it might roud the edges due to the scr turning on.
Offline Paul Moir
« Reply #11 on: January 08, 2015, 09:59:04 pm »
FET output opto, not SCR.  Like this:
http://www.digikey.ca/product-detail/en/H11F1M/H11F1M-ND/1793945
Just makes it on breakdown voltage (+-15v RS-232 not 25).  You'd probably want to drive it at 10mA each to get the resistance down nice and low.
EDIT:  Toshiba's got some higher voltage ones:  TLP3119
« Last Edit: January 08, 2015, 10:06:46 pm by Paul Moir »
Online edavid
« Reply #12 on: January 08, 2015, 10:04:33 pm »
RS232 and buses don't really go together - what is it you are trying to do?
Anyway, since it's not a bidirectional signal, you don't need a switch.  Just use an RS232 transceiver with shutdown, for example the LT1039.
Offline Paul Moir
« Reply #13 on: January 08, 2015, 10:07:17 pm »
Good point!  :)
« Reply #14 on: January 08, 2015, 10:33:18 pm »
Yeah perfect i knew there was a simple solution that part you linked is eol.
Buy anyways i am sure there are others looking now.
Could probably make this work too dosen't have the shutdown but has enfo i/o that i could make it work.
http://www.mouser.com/ProductDetail/Texas-Instruments/GD75232PWR/?qs=sGAEpiMZZMutXGli8Ay4kCi9xQZvT4qAT8kgJZ1ZuVc%3d
Also its not really a bus but thats just an easy way to describe it. Basically i am making a serial console switch so i can switch between devices only one will be active on the "bus" at a time and the receiving end obviously.
« Last Edit: January 08, 2015, 10:42:34 pm by kingofkya »
Offline Wilksey
« Reply #15 on: January 08, 2015, 10:34:34 pm »
I was thinking relay rather than analog switch, I have used some quite small 5v relays from Farnell /Element 14 in the past for similar things.
But as others have said, RS232 is not usually good on buses.
Online edavid
« Reply #16 on: January 08, 2015, 11:37:00 pm »
No, it's still available everywhere (although not cheap):  http://www.findchips.com/search/lt1039
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #17 on: January 08, 2015, 11:56:15 pm »
Depending on what's already connected to the buss, consider diodes to steer/isolate the source.
Sometimes a couple of well placed schottkys can provide a simple 'no-moving-parts' merge of true +/- RS232 streams.
Also works with singler-ended signals as well - just work it through on paper.
Don't ask a question if you aren't willing to listen to the answer.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #18 on: January 09, 2015, 01:33:39 am »
Perhaps a cheaper alternative: SN75C1406. Price at Digikey.
Offline Paul Moir
« Reply #19 on: January 09, 2015, 02:35:33 am »
I don't think that one, nor the other one the OP picked out has a shut down mode.
