Author Topic: Power Supply Question  (Read 966 times)
Offline CramboneTopic starter
« on: July 11, 2024, 10:42:00 pm »
I know this is limited in information but manufacturer won’t release a schematic. Unit is an ACOM 1200S linear amplifier for 1.6-50MHZ
To start the 1200S let out a pop and then dead. I opened it up and found C4 Safety Capacitor blew on power supply. Replaced with new and still nothing but RY1 clicking.
I followed the 120VAc and it goes to 2 relays in Normally Opened state that are activated by 12VDC. The relays aren’t closing so I pulled them and tested and they close perfect with 12VDC .5A applied. Placed them back in and jumped the contacts from normally open to closed. Following the 120VAC I come to a Bridge Rectifier. 2 inner posts have 120VAC. The 2 outer posts are showing +130Vdc or -130Vdc depending on probe orientation. I’m also seeing 20Vac on the same outer posts. I don’t recall ever seeing both DC & AC out of a bridge rectifier.
Questions
1) if I’m seeing 12VDC on both relays why won’t they close? I didn’t measure the current.
2) Should a bridge rectifier pass both DC & AC? Maybe just pulsating DC I may check the frequency.
Andrew
Offline Vovk_Z
  • Country: ua
Re: Power Supply Question
« Reply #1 on: July 12, 2024, 02:11:23 am »
You test diodes and bridges with a diode test feature.
A (cheap) multimeter may show everything at DC/AC modes.
« Reply #2 on: July 12, 2024, 02:45:25 am »
I have a partial schematic of the circuit in question now.
RY1 (relay) (yellow) chatters when powered on and won’t stay closed.
J200 & J201 (green) have 120vac
K202 & 203 (blue) N/O relays won’t pull closed even though I show 12vdc across A1 & A2 coil. Pulled relays and tested good.
If I jumper the relays so 120vac passes at the bridge rectifier (green) I have my 120Vac on legs 2 & 3 and I get 130Vdc & 20Vac on legs 1&4?
what would cause relay K202 & 203 to not stay closed with 12Vdc on them?
Why the 20Vac on rectifier legs 1&4?
Offline perieanuo
« Reply #3 on: July 12, 2024, 08:56:55 am »
I suggest stoping bypassing relays before You understand the fault.
After rectifier You get DC normally If filter capacitors are fine. You said You get AC, maybe one rectifier diode îs dead.
The following users thanked this post: Crambone
Online Kim Christensen
« Reply #4 on: July 12, 2024, 03:00:42 pm »
That's just ripple. It's normal to see some "AC" on a DMM set to AC at that point in the circuit.
It looks like this power supply has PFC (Power Factor Correction) which is probably why there appears to be a lot of "AC" (Actually pulsating DC) after the bridge rectifier. (As compared to a traditional linear power supply)
ie: There's no large filter capacitor immediately after the bridge rectifier in a PFC supply.
« Last Edit: July 12, 2024, 03:02:57 pm by Kim Christensen »
« Reply #5 on: July 12, 2024, 08:33:01 pm »
Copy of full schematic posted now.
Andrew
« Reply #6 on: July 12, 2024, 08:35:10 pm »
Interconnect Diagram if this helps?
« Reply #7 on: July 12, 2024, 08:44:33 pm »
UPDATE, I was able to pull a HARD FAULT log from the unit and it shows LOW or NO 26V on Power Supply
Andrew
« Reply #8 on: July 12, 2024, 10:16:09 pm »
Well, you should have some high voltage DC across across C16/C17/C18. This HVDC voltage is what feeds U2 (TOP244), a small switching power supply, which creates the 26Vdc source for U7 (which creates 5Vdc) and 26Vdc for other circuitry. (via J1A-8, J1B-4, etc)
Perhaps U2, or some of it's associated circuitry, is defective? Or there is a short on the 26V line?
Offline Chris56000
« Reply #9 on: July 13, 2024, 03:45:05 pm »
. . .Where did the schematic come from? There might be extra sheets covering the PFC and PWM sub–panels!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
« Reply #10 on: July 13, 2024, 10:03:51 pm »
Here is the PFC schematic
« Reply #11 on: July 13, 2024, 10:06:13 pm »
Control Board schematic
« Reply #12 on: Yesterday at 02:37:08 am »
PCB1 9. Dead short 0.03 ohm   XXXXXXXXX
This is normal. You can see pin9 (Down-arrow ground symbol) joined to ground at the "junction point" just under U4 on the DC1500 CNTRL BOARD Unit.
J1A & J1B connection  All 26V ohms go from 0 to 1900 then OPEN XXXXXXXXXX
Normal to see when capacitors are charged up by an ohm meter. Get a 470uf or more capacitor, discharge it, and then ohmmeter it to see a similar effect.
J101  Pin 1 shows open (J101) is normally Not Connected XXXXXXXXX
Normal.
Also what is FCOM ? I see it all over the schematic?
It is the non-isolated, rectified mains voltage, negative potential. (BD1 pin 4) Dangerous point to put a scope probe's ground clip. (Don't do it!)
« Last Edit: Yesterday at 02:42:50 am by Kim Christensen »
« Reply #13 on: Yesterday at 03:30:50 am »
I wish I had a way to send or post the Tech bulletin with all the schematics.
« Reply #14 on: Yesterday at 04:26:15 am »
You could print the tech bulletin to PDF and post it. As long as the file is less than 8 MB.
I notice you tried to post the PFC schematic, but I see nothing attached to that comment.
« Reply #15 on: Yesterday at 04:35:32 am »
Yes it’s too big
Ok I have the PSU out of the unit no interconnections, I applied 120Vac and took voltage readings. The red highlighted is where I am seeing 11.7 to 12VDC.
I then decided to check the J204 interconnect cable that becomes J502 at the CPU board. When I checked the interconnect cable to chassis ground of the unit not connected to PSU I am getting a direct contact to ground on pins 1 & 4.
« Reply #16 on: Yesterday at 05:03:33 am »
Well that makes sense, since these pins (1 & 4) are grounded on J502 of the CPU unit.
« Reply #17 on: Yesterday at 05:52:39 am »
OK I see that now, man I’m learning a ton thank you. So what am I missing? Why won’t the 120vac relay close?
Andrew
« Reply #18 on: Yesterday at 03:44:26 pm »
Refering to the "ACOM 1200S PS Unit" PCB.
When the user is pushing the "on button", pins 5 & 6 of J205 are shorted together & grounding pin 6 of J205. This turns on the relays via D208 and starts the power supply. This also lights the LED inside U201 which turns it's transistor on. That makes J204 pin 3 go low which signals, to the now powered up CPU Unit, that the button has been pushed. If the CPU decides that all is well to stay powered up, then it'll output a voltage on J204 pin 2 (J502-2 ON_HOLD# on CPU unit) which will light the LED in U202 and turn on it's transistor. This will put a voltage (6V) on the gate of Q200 causing it to turn on and keep the relays turned on.
« Last Edit: Yesterday at 03:59:49 pm by Kim Christensen »
« Reply #19 on: Yesterday at 06:21:53 pm »
Did you ever check to see if the 26V was there while the power button was pressed? That could be why the CPU shuts the power supply down.
(J1A pin 8 on ACOM 1200S PS Unit)
« Last Edit: Yesterday at 06:24:45 pm by Kim Christensen »
« Reply #20 on: Today at 02:13:20 am »
Kim, I just tested with CPU back in unit and J1A pin 8 has no voltage even when power button is pushed multiple quick times.
Andrew
« Reply #21 on: Today at 03:05:12 am »
Press and hold the power button for a couple of seconds while measuring J1A pin 8.
If there's no voltage at all, then press and hold the power button for a second or two while carefully measuring the high-voltage rectified DC at a convenient point. (+ of C16,17,18 or 21; cathode of D4 or D3; etc, referenced to FCOM) If F1 (fuse) is OK, you could also measure between pins 1&3 of J101 instead. Should be something like 160V or more.
« Reply #22 on: Today at 04:34:55 pm »
Kim thanks I will try on Thursday when I return home, I really appreciate all the help!.
Andrew
