First post, be gentle...
I'm trying to repair a treadmill i recently bought, it has something wrong with wax/lift/power distribution board.
(Will explain nature of troubleshooting/repair in repair section).
Problem is, the item was sat in a garage for way too long. Being in UK doesnt help matters either, weather is crap most of the time, damp, etc... The board in question got gray corroded looking joints all over the place. No corrosion to vias or board itself. It doesnt stick to my iron. Its as if my iron is not powerful enough (30w).
I heat joint up, solder liquifies and wont stick to iron at all. Fresh solder (60/40 mc) wont stick to it as well. I managed to desolder one very suspect cap and now cant clean the holes, braid wont wick it away. Had to pull cap forcibly just to detach it from the board while non sticking solder is liquid... Desoldered cap couldnt be resoldered by new solder. Had to knife scrape gray whatever off legs to get fresh solder to stick... Tried couple easier components - one diode and one resistor. Same there. Quit at that point... Dont want to ruin the board by my amateurish attempts to revive it by resoldering.
How to remove solder if it wont wick or suck away with a plunger/sucker ? No amount of flux helps (kester 951 pen).
Soldering iron in question is a cheapie 30w hot stick from some big box store... many moons ago...
My soldering skills are...emmm...fair...ish... Managed to jtag an xbox360, that counts for something no ? Kynar wire and all that...
Do bits and pieces here and there, fix crap my kids break etc, no smd's tho (except for a R6T3 removal on xbox
My electricity/ee knowledge is basic, i've been around computers most of my life (christmas computer fixing marathons suck), i understand very basic ee components.
Anyone to help me solve this ?
P.S. Cant just shove it into oven for reflow as there are relays, transformers and caps present. Not keen on wrecking it completely.
