Just to add to what the others have already mentioned, I always try to avoid routing traces underneath ICs. It's not the worst thing with DIP packages, but it will mean you get an unbroken ground plane under it.
You could try bringing the track that connector to pin 4 of the PIC out and going around to the left of the controls connector, or perhaps change the pins entirely so that they route more neatly (that may not be possible depending on what the connector is for).
