Author Topic: Rookie RMS DMM question  (Read 4144 times)
Offline boulderjoeTopic starter
« on: February 09, 2012, 03:54:08 am »
Hey All- I have a question about RMS DMMs. I have an Extech 22-816 RMS DMM (sold through radioshack). The readings are all over the place until it gets a strong signal, which makes trouble shooting things a pain!. With the cables attached to nothing it will range from 800 volts to 0, then back, all in random order. When hooked up to a power source it will eventually hit the right voltage, but it takes time.
So before I pick a new meter up (for eletronics hobby, arduinos, blinky leds, those types of things if you have a suggestion; budget up to $150),  is that random auto ranging normal?
Thanks for the help with the rookie question.
-Joe
« Last Edit: February 09, 2012, 04:02:18 am by boulderjoe »
Offline IanB
Re: Rookie RMS DMM question
« Reply #1 on: February 09, 2012, 04:02:37 am »
Most of the higher performance multimeters show random display readings on DC volts ranges when the probes are free floating. This is because the high impedance input (usually 10 M or more) allows the meter to measure voltages induced in the leads by stray electric fields. The reading should settle down once the probes are attached to a circuit.
To avoid this problem you can buy a very cheap meter. The cheaper meters are less sensitive and cannot measure such small signals.
« Reply #2 on: February 09, 2012, 04:05:46 am »
Thanks for the answer, that makes sense.
If I have the probes attached to a LED or other part, when their is no power going to the part, is exhibits the same behavior of numbers all over the place. Is that normal in RMS DMMs too?
Thanks for the info!
-Joe
Offline vk6zgo
« Reply #3 on: February 09, 2012, 04:14:58 am »
I doubt if there has been a DMM which doesn't have a 10M input impedance,since they were first made.
My old Fluke 77 doesn't exhibit this behaviour,or the far more recent Fluke I used in my most recent job.
I can understand a DMM reacting to randomly picked up signals if locked to a very sensitive range,but not otherwise.
Offline IanB
« Reply #4 on: February 09, 2012, 05:06:43 am »
-Joe
No, it doesn't seem quite normal. The voltages should only be small when the probes are free floating. A fraction of a volt, say. As soon as you attach the probes to an unpowered part like and LED the display should quickly go to zero.
You might want to check how it measures a known voltage like a battery. You could also check that both probes are properly seated in the sockets. With some meters the probe plugs need a slightly firm push into the meter sockets to engage properly.
Offline IanB
« Reply #5 on: February 09, 2012, 05:08:24 am »
I think Fluke do some special display damping in their meters. Because some people get concerned about the wandering values they do something to squelch the display reading until a circuit connection is detected.
Offline AlphZeta
    • Kerry D. Wong
« Reply #6 on: February 10, 2012, 03:18:24 pm »
This type of behavior is not that uncommon among auto-ranging DMMs, and in some it's more pronounced than others.
But most auto-ranging DMMs have a manual override option so that you can lock the range at a particular resolution to prevent this type of behavoir.
« Reply #7 on: February 12, 2012, 03:27:44 am »
Thanks everybody for the info. By locking it in to the lowest range (which is all I deal with) it works good enough. that was the trick.
Thanks!
-Joe
