I nearly posted this in the repair section for the forum, but as I'm a beginner it's probably better here...
I have a smps from a Reebok treadmill. The treadmill doesn't appear to power up at all.
I've ordered a complete set of caps, tested the diodes and bridge rectifier. The coil also seems to be good.
I've got as far as testing the DC output of the bridge rectifier.
What should I do next?
Thanks!
