The 4.7 uF used is this one: C2012X7R1H475K125AC
https://product.tdk.com/system/files/dam/doc/product/capacitor/ceramic/mlcc/catalog/mlcc_commercial_general_en.pdfDriver supply voltage is 24 V.
I have to do some measurements again and zooming into the step, forgot to take pictures of these. What I remember from it is that it is super fast ringing, the ringing is just for a few nanoseconds approximately < 10ns if I remeber correctly, and it is a few periods during that time.
The voltage peak can reach to around 35 V (when it should go to 24 V.) The same goes for the 0V output it can reach almost 10 V, and there is a overhearing between output 1 and output2 which is visible in the oscilloscope pictures as the quadrature signal is phase shifted 90 degrees, it is visible that all edges affect eachother.
I have also measured at the voltage supply which is a standard variable lab supply and I can see the voltage ringing even there, so my guess here is that they are interfereing eachother through the effect to GND and/or Supply.
Even if I go down to say 30 Hz for my input, my understanding was that it still creates the same type of ringing when it comes to peak, decay and frequency.
But I have to do some more measurements looking into these details.
Measurement setup:
During the measurement nothing is really connected, the leads running out of the pictures goes to a board connector where no cable is connected.
The two holes seen are standard 2.54 mm header pins I put there to be able to jack in and analyze the signal.
There I have connected my oscilloscope probes with the "springy pin".
The ground of the probe is connected to a separate ground pin on the board (I guess it becomes a long return path).
I have also connected jumper wires to the 2.54 mm header pins to another inverter board that just inverts the signals and then output to screw terminals, where I have tried to connect a 100 ohm resistor and then measured after the resistor. The resistor dampens the peaks a little but not much.
As I also mentioned earlier, there is really no load connected to the outputs of the IX4427N, basically free floating.
I put the ESD diodes there because the outputs goes to a board connector so I "thought" it would be nice to protect it with an ESD diode. But it was more of an extra layer of protection but they introduce capacitance towards my ground plane, so maybe a good idea to just try without them.
Jeroen3:
"Is it ringing in the gate driver circuit or so called switch node ringing on the mosfet drain?"
Switch node ringing on the mosfet drain, is this the mosfet within the gate driver, because I have no other mosfet in this layout except for the ones inside IX4427N.
Yeah, shouldn't have that long of a route from my driver output back to its own ground. When he has pointed it out it seems so obvious.
But as I don't have a mosfet gate at the output of IX4427N, the return path would be long as it is intended to go through wires to another high impedance input that even maybe on another board with the grounds connected.
I guess one of my mistakes here is that I have used the IX4427N, it feels like it's more targeted at driving another mosfet, I guess I really just wanted a N-channel low side MOSFET with an inverter.
Then I would have been able to tune the gate resistor with the gate capacitance to put it at the correct cut-off frequency for my application?
Is it even possible to have a circuit as IX4427N for the purpose I'm trying here?
