Indeed, just keep increasing the current until the LED starts to release magic smoke. The maximum current is somewhere below the current indicated by the DMM just before the LED died. Use three current sources and DMM's for an RGB LED.
yup guys. i forgot the resistor!
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
think i'm going to do the same mistake twice! thats how i burnt a LED (no resistor). i got no magic smoke, just a magic dimming effect and dead forever. to find out max rating, u can use 100K potentiometer maybe and turn down bit by bit until the magic smoke
. what i understood and try to explain is, the OP try to figure out whether the 20mA is for single color LED or all the RGB alltogether. so he can check each power line, or all of them at once
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
so, if the supply from battery is 20mA and the LED is not bright enough, then try feed it with 60mA!
