Author Topic: Air purifier stops working after cleaning  (Read 952 times)
Offline thomwoTopic starter
« on: April 19, 2021, 09:17:08 am »
I bought a rensair air purifier recently which it think is best for viruses. it works fine but today i plan to clean it up, after clean up when i switch on it fails. what could be the reason?
its me Wood
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Air purifier stops working after cleaning
« Reply #1 on: April 19, 2021, 11:43:12 am »
If it's that recent return it.
The following users thanked this post: thomwo
Offline BILLPOD
« Reply #2 on: April 19, 2021, 01:40:33 pm »
Good Morning Thomwo,   IF you removed the filters, go back and check their orientation.  The filters on mine, (different brand),
have electrical contacts that have to mate up with other contacts
in the machine.  So, If I don't install the filters in the EXACT
position, it won't run.  RTFM :-/O
« Reply #3 on: April 20, 2021, 10:42:52 am »
Thank you. @Simon
I checked the purchase date, only 2 days are remaining for warranty expiry. I will definitely return it. My selection was wrong, i choose rensair from the 4 other brands.
Which one i should buy that is really best for home use/
1. Levoit (https://levoit.com/)
2. Rensair (https://topbestairpurifiers.com/rensair-air-purifier-reviews/) i was impressed from this review on facebook because they claim it is hospital grade and work best for ooronavirus - (I'm disappointed)
3. Alen Breathe (https://alen.com/products/alen-breathesmart-hepa-air-purifier)
4  HoneyWell (https://www.honeywellstore.com/store/category/air-purifiers.htm)
« Last Edit: April 20, 2021, 11:05:25 am by thomwo »
its me Wood
« Reply #4 on: April 20, 2021, 10:45:48 am »
@BILLPOD Actually i tried to reinstall the filter, but same.
its me Wood
Online SmokedComponent
  • Country: si
  • Emitting smoke
« Reply #5 on: April 20, 2021, 01:20:08 pm »
Good Morning Thomwo,   IF you removed the filters, go back and check their orientation.  The filters on mine, (different brand), have electrical contacts that have to mate up with other contacts
in the machine.  So, If I don't install the filters in the EXACT position, it won't run.  RTFM :-/O
I found out that the funny way. I accidentally kicked mine over and it stopped working. Great... Naturally, I took it apart... and noticed there's a switch by the filter module and the filter just came loose a bit. Pushing it back solved the problem.... so I took apart a mundane device with many screws for no reason.  :palm:
