For a FET, the answer is "maybe". FET is capacitive load, and there are many many factors if you need a 20-100ohm there or not.
You usually dont place resistors between CMOS or TTL circuits, because it is usually unnecessary. The same way, you usually dont use faster logic gates, than what you need. But that doesnt mean, that sometimes these resistors are not needed.
See, it all depends. Thats the beauty of engineering, you start with some generalized rule, and as you do more and more projects, your decision tree gets bigger and bigger.
