Author Topic: Requesting advice for diagnosing a stereo issue  (Read 546 times)
Offline StereoAmateurTopic starter
« on: July 17, 2023, 01:13:16 am »
Hello everyone,
first I apologize to the site staff because I had an older account here with just a few posts but i lost access to that email address completely and could not reset that accounts password.
Anyway here is my question:
I have got some Technics SB-A52 speakers, these are 3 way floor standing speakers with two large woofers, a smaller midrange speaker and a tweeter. I am not a picky audiophile or anything.  I have hearing loss and got these for a $20 on the local marketplace because i wanted some louder speakers.
When I use the speakers the volume occasionally drifts a bit, so the volume gets quieter for a bit  (maybe 10 to 30 seconds) before it kind of fades back to how it was.
How can i find out if the crossover is damaged? I don't really understand how speaker crossover work but I was curious if that might be the cause of the volume drift issue.  I do understand these had a cheap crossover in them. I have no idea how to know if the crossover is blown. I found  a few comments online when trying to find info on these speakers that people found the crossovers were blown out and it sounded better after replacing those.
I figured whenever i open them up i will make sure all the wiring is good and replace any questionable or loose wiring.
I know my amp is not faulty because I have a couple amps to test with and the volume drift eventually shows up with either amp I have.
I would be grateful for your advices.
Online MathWizard
Re: Requesting advice for diagnosing a stereo issue
« Reply #1 on: July 17, 2023, 01:36:32 am »
So if the crossover thingy has a bunch of electrolytic caps on it, I'd want to check them. IDK why the audio level would fade for a while and return. Maybe some bad caps and diodes could act like that.
Online themadhippy
« Reply #2 on: July 17, 2023, 01:43:28 am »
is it one or both speakers? if its both then id be looking closer at either the amp or signal source.
The following users thanked this post: 807
Offline Ian.M
« Reply #3 on: July 17, 2023, 02:06:12 am »
If it was a bad connection you'd probably hear a crackle as the sound comes and goes.  If not, most likely the problem is with your amp or even the signal source
Offline EPAIII
« Reply #4 on: July 17, 2023, 03:56:12 am »
What are you listening to when this happens? I have noticed that when I use my Roku Express devices to connect to streaming services on the web that on some programs the audio will be lower after a commercial break and then fade back to full level in 15 to 30 seconds. It could be the streaming source or a setting in the Rokus that is there to fight the loud level of some commercials.
I haven't investigated this yet.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Offline wasedadoc
« Reply #5 on: July 17, 2023, 08:45:13 am »
There is close to zero probability that two loudspeakers have faults which cause them to change volume simultaneously.
Offline Vovk_Z
  • Country: ua
« Reply #6 on: July 17, 2023, 12:31:12 pm »
+1.
