Just to add to what septer012 said, if you want to make full use of your transformer using a linear regulator then, under worst case conditions (max current, 0v out), you will have to dissipate about 1000w in your power supply (2 x 18V x 30A). Not impossible but not trivial either.
Try looking in some of the amateur radio books, such as the ARRL handbook, hefty low voltage power supplies are popular for powering their portable gear.
Jim
