Only non electrolytics that are replace on sight are those wax encased paper types, as the wax crazes with time, and the capacitor picks up moisture in the paper. Other types are certain mica capacitors, specifically the very early micamold types, which have a dot code to indicate the value. Other than that, most capacitors are quite reliable, aside from tiny little glass and dipped ceramic capacitors from the 1980's to around 2000, which have a higher failure rate.
