Ok, I've been reading on batteries and charging, and it sounds like:
- All NiCD batteries will eventually leak
- NiCD charging circuits are not suitable for either NiMH or LiR batteries. (the original DataSentry is a NiCD)
SO...
I think the easiest / cleanest option may just be a non-rechargeable option with a Q2 disconnected to prevent charging.
Which brings me back to my original question, sort of: How do I figure out if a CR2032 3V would be enough to keep the ram alive in this synth? (other than actually doing the mod to see)
In the Korg PolySix, a 3V battery worked fine at keeping ram that was originally kept alive by a 3.6V NiCD. But the RAM in the current synth may not be the same.
The standby current info in the synth's RAM is cryptic to my newbie eyes, so I asked ChatGPT to clarify things for me. I gave it the data from the datasheet and it said:
Isb (Standby Power Supply Current):
Symbol: Isb
Minimum: Not specified
Typical: 1 mA
Maximum: 3 mA
Unit: mA
Test conditions: CS1̅ = Vih, CS2 = Vil
This specification indicates that under the specified conditions (CS1̅ = Vih and CS2 = Vil), the typical standby power supply current is 1 mA, with a maximum of 3 mA.
Isb1 (Standby Power Supply Current with Additional Conditions):
Symbol: Isb1
Typical: 2 mA
Maximum: 50 mA
Unit: mA
Test conditions: CS1̅ ≥ Vcc - 0.2V, CS2 ≥ Vcc - 0.2V, or 0V ≤ CS2 ≤ 0.2V, 0V ≤ Vin
This specification provides additional conditions for standby power supply current. It suggests that under the specified conditions (CS1̅ ≥ Vcc - 0.2V, CS2 ≥ Vcc - 0.2V, or 0V ≤ CS2 ≤ 0.2V, and 0V ≤ Vin), the typical standby power supply current is 2 mA, with a maximum of 50 mA.
Now, let's relate this information to the DC Characteristics provided:
Vcc = 5V ± 10% (which means Vcc can be in the range of 4.5V to 5.5V).
Vss = 0V
When the chip is in standby mode, it is drawing the standby power supply current, and these values are given based on different conditions (CS1̅, CS2, and Vin). CS1̅ and CS2 are likely control signals, and Vih and Vil are voltage levels for logical high and low, respectively.
To summarize, the HM6264LP-15 RAM chip's standby power supply current can be in the range of 1 mA to 3 mA under certain conditions and 2 mA to 50 mA under additional conditions, depending on the states of control signals and voltage levels.
Tres cool. But I'm not sure how the control signals are used in this synth.
I'm also unsure of how Voltage and Amperage plays out here. The battery is directly connected to the RAM chips except for the diode CR5. A CR2032 can
typically provide 0.19mA at 2.9V. ChatGPT seems to be saying I'd need 1mA *minimum*, more like 3mA, to keep one RAM chip alive, and there are 8 chips. So a CR2032 wouldn't cut it then? I'd need at least something capable of providing 8mA, possibly even 24mA?
I can't seem to find the capacity of the original DataSentry battery, @tszaboo suggested it was something like 150mAh... I asked ChatGPT directly if a CR2032 could keep 8 of those RAM chips alive, and it said yes, for 9.7 hours. Which isn't anywhere near enough.
Does that make any sense? (ChatGPT is questionable at times)
Should I
consider a CR2 then? (CR2450 don't seem much beefier)
