I would like to remove a hall effect switch and install a push button switch. The hall effect switch I would like to replace is a two-wire hall effect switch. Currently I have a HAL566 installed and want to remove the sensor. This will enable me to push a button to do what I want.
This hall effect switch changes how it behaves in the presence of the magnetic field. The sensor changes the current consumption from below 5mA to about 15mA when the magnetic field is applied and taken away.
I have attached the datasheet but am no electrical engineer and am unsure how to recreate this circuit with a push button switch.
Can someone help me or teach me how to create a circuit to change the current so precisely with a push button.
The hall effect switch is more complex internally and I don't fully understand it.
" alt="" class="bbc_img" />
Image from Melexis guide that is attached.
I have found several two wire hall switches all doing the same thing but searching online could not find how to easily replace one with a manual switch. Thank you to anyone who can help.
