Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Stepper motor inrush current
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Stepper motor inrush current (Read 2013 times)
tony3d
Frequent Contributor
Country:
on:
September 23, 2017, 01:41:05 pm »
Just wondering if the current induced be manually pushing a 3d printer bed around, can damage the printers circuitry?
Logged
Karlo_Moharic
Regular Contributor
Country:
Re: Stepper motor inrush current
Reply #1 on:
September 23, 2017, 03:16:23 pm »
Unless you are pushing the bed with 10G of force , the answer is no. You will induce a couple of milivolts , maybe a volt at most.This is too small of a voltage to damage anything.
Logged
tony3d
Country:
Reply #2 on:
September 23, 2017, 04:46:18 pm »
I can very easily spin the shaft of a small D.C. Motor, and generate over 3 volts. Moving a bed even rather slowly looks faster.
Logged
Karlo_Moharic
Regular Contributor
Country:
Reply #3 on:
September 24, 2017, 08:46:43 pm »
It would took several hundred volts for you to damage something , you have nothing to worry about.
Logged
Shock
Super Contributor
Country:
Reply #4 on:
September 25, 2017, 11:46:57 am »
Thou shalt measure, with thy min/max.
Logged
Multimeters: Fluke 189, 87V, 117, 112
>>> WANTED STUFF <<<
Raj
Country:
Self taught, experimenter, noob(ish)
Reply #5 on:
September 25, 2017, 05:53:35 pm »
unless you have a badly designed circuit,no.
most motor drivers have diode protections built in.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
