SSRs are full of traps, and even if seemingly simple on surface, require quite some understanding. Most importantly, minimum voltage, more strict maximum voltage with little margin against line transient voltages, minimum load current which can be surprisingly high, minimum power factor requirement, large leakage current, and so on.
But thankfully, this is an electromechanical relay. Which is free of the mentioned issues, but comes with completely different set of traps: large enough coil current that you usually need some kind of driver, inductive nature so need freewheeling circuit, limited number of cycles, even more reduced number of cycles due to severe arcing if you use freewheeling diode instead of a better solution (I recommend bidirectional TVS), EMI generation, again minimum load current which is often unspecified - contacts require some amount of arcing to stay clean. And so on.
In the end, this does not matter too much if you are just playing around and not designing a robust product. I would drive this directly off the AVR IO pin, even though the nominal coil current (47mA) would exceed the pin rating, but it's fun to live on the edge; or, I would parallel two IO pins and make sure to always switch them together in software. Although, if the AVR is powered from 5V and not 3.3V, then you should be looking at EE2-5NUH instead - nominal coil current of 28mA is under the maximum rated pin current. And, the complementary IO structure provides freewheeling. Try it.
