Well it's that time again of doing my now HND course assignment which as always is in monkey see monkey do fashion given the very selective information in the course module. This one is causing me a dilema around powers and voltages.
An amplifier has a bandwidth of 80-862 MHz
a gain of 20dB
Noise figure of 6 dB
Max output 85 dbµV
Input impedance 75 Ohms
Output Impedance 75 Ohms
If the signal level from the aerial is 5 dBmV and the input noise level is 20 dBµV, calculate the signal-to-noise ratio on the output of the amplifier.
So firstly as the source impedance has not been specified (this figures in the modules calculations) so I would assume also 75 Ohms. So do I assume the amplifier see's the full 5 dBmV and 20 dBµV or half due to the cable also having an impedance of 75 Ohms (I assume).
To convert from dBmV to dBµV I am unsure if I add 30 or 60 dB. I gather that 20 log V/µV is caveated by the impedances being the same which is standard.
If i assume 60 dB then that does make my noise ratio more plausible. So the 5 dBmV is 65 dBµV, this makes sense as knowing how these people operate they like to make things all tie together to help you see if you are getting it right at 65 dBµV is the answers toe tthe previous question about the same amplifier asking for the maximum permissible input given the specs.
Does the SNR change whether expressed in dBmV or dBmW ? I guess being a ratio no as all things being equal the ratio is the same.
