Hi all,
I usually stick to GPU's but managed to get hold of an Asus Z97-Pro motherboard which has difficulties turning on.
The POST codes flicker through and dies without pausing at a specific code. Then proceeds to enter an infinite reboot loop.
I've found a component that seems to be shorted internally - with the motherboard being on for just 2 seconds it was good enough to burn my skin on touch.
As per the title, the marking on the IC is:
29 1B
L1B
Any ideas on where I could source the datasheet? Asus may have rebranded it but am not sure why they would...
Thanks for the help!
