Thank you for your replies. No not hundreds of Amps, the most would be 30 Amps at 12.00 Volts to 13.80 Volts. Might go as far as 50 Amps at that same voltage in the future, but it's only a maybe. Some years ago I had a retail linear power supply 13.80 Volts DC go high voltage, the potentiometer for voltage adjustment failed letting the full unregulated voltage through, about 22.00 Volts from memory. I was lucky nothing was connected to this 3 to 5 Amp linear power supply. What I use these homebrew power supplys for, is mainly HF radio equipment, mostly CB radio gear. I have a 12.00 Volts DC 15 Amp PSU and put together a separate crowbar circuit for it in a small project box. I have tested it with over voltage scenario, and it does fire and blow the fuse very quickly, or it seems quick to me. After replacing the fuse the crowbar is good to go again. What I would like is to incorporate the crowbar circuit as part of the PSU circuit on one board. But I have constraints with space. I've got as far as a 30 Amp power supply using a L7812 with 6 X TIP36C PNP power transistors. And it's very impressive with regard to power and stability. I'm tempted to use it with just primary and secondary short circuit protection, but there's that niggle, what if a transistor failed and it put out the 21.00 Volts rectified and filtered unregulated voltage. I expect I will be safe and use a crowbar circuit, just a though, could the crowbar circuit cartridge fuse be replaced with a thermal resettable circuit breaker ? Or is one of those to slow to act upon a fault.
