200mm isn't very long. 10nF between GPIO and Gnd may be added if it does pick up too much noise. Instead of the SMD BAT54S, you can substitute 2x any other small signal axial leaded Schottky diode you have handy, one between Gnd and GPIO, and the other between GPIO and +3.3V, both cathode positive. Anything rated for 30-200mA and <=100V should be suitable, but avoid >=1A or >100V power Schottky diodes.
However, what you've designed wont harm your Pi, so if it exactly meets your requirements, and you can build it immediately, for free out of junkbox parts, the only downsides are its size and complexity, and the extra approx. 5mA current it wastes.
