Loading [MathJax]/extensions/Safe.js
Author Topic: Doubts about SPICE analysis  (Read 1412 times)
Offline RawCodeTopic starter
« on: March 09, 2019, 09:59:08 am »
Hello there!
I'm an electronic enginering student, and at the moment I'm attending the ECAD subject. I use Micro-Cap 12.0.2.1 Evaluation Version as a ECAD software, and at the moment I can't switch to something simpler like LTSPICE, since i have to take an exam with Micro-Cap.
First thing: what is, what is the purpose and when i should use the PSS(Periodic Steady State) analysis in the transient analysis?
I was messing around with a guitar effect, but I found something strange in the simulation.
Let's start.
First thing strange: i was studying this buffer stage, which has this spectral response:
Is that normal that i get a transient response (a sinusoidal wave @60k) of this kind? I mean, i know that there is a resonance at more or less 11kHz, but i didn't expected this behavior at the beginning, because i'm "far" from the resonance.
(Blu=input, Red= output)
Here it is another strange thing. I was analyzing the input and output impedance of this stage with the ac analysis - i'm using a what micro-cap calls "generic model" for the opamp.(blu=input, red=output)
But in the plot of the analysis, it shows something strange, like a "resonance of impedance" at more or less 12kHz of almost 1Meg, and everywhere else an impedance of 10k. For me at least this is very strange, because i expected something near zero impedance.
but if i remove the toggle to the option "operating point" i get this kind of impedance, which is more "reasonable".
What am i doing wrong? Can you help me?
« Last Edit: March 09, 2019, 10:04:07 am by RawCode »
Online exe
  • self-educated hobbyist
Re: Doubts about SPICE analysis
« Reply #1 on: March 10, 2019, 10:15:04 pm »
The oscillation could compensation/stability issue of the opamp. Which opamp is that? Anyway, I'd first increase the compensation cap to see if behavior changes.
« Reply #2 on: March 12, 2019, 07:56:20 pm »
I'm using the ne5532.
I solved the issue with the impedance though, doing the analysis of the input impedance grounding the output and vice versa. I thought that I could do the complessive impedance analysis in one shot
Inviato dal mio LG-H930 utilizzando Tapatalk
Online exe
« Reply #3 on: March 13, 2019, 08:35:08 am »
Did you ground the output of opamp?
« Reply #4 on: March 22, 2019, 08:46:45 am »
Yes I did.
Anyway I solved this simulation issues and all my doubts.
Online exe
« Reply #5 on: March 22, 2019, 11:57:28 am »
Could you please explain why grounding is needed? I thought input impedance of opamps is generally high and not related to output anyhow (unlike a bjt amplifier). Also datasheets mention input bias current, this should sort of tell the input impedance immediatelly. Or you mean impedance of opamp input and surround circuits?
