I'm attaching the schematic I created and the datasheet. Can someone please review it?
1) The IP5328P is a custom symbol created by me, when I connect a Label to the pins it creates a junction but no junction is created for single connection on pins in the USB ports(kicad default symbols). Did I make a mistake while creating the symbol?
2) I hope the Gate, Drain and Source pins of the MOSFETs are properly connected.
3) They have used a Electrolytic Cap for C15. Can I use the same? Will any SMD cap should be fine for others?
4) The pins VSYS,VSN and VSP are connected together. I have tried to follow the the diagram on top of the datasheet, have I done that correct?
